It would give scientists their first close-up views of Uranus since NASA’s Voyager 2 flew past and captured fleeting pictures 25 years ago.
The £400million mission is designed to go in orbit to study the rings around Uranus and answer questions such as why it gives off so little heat.
Uranus – first spotted by Sir William Herschel from Bath, England, in 1781 – also has the most powerful wind ovserved in the solar system, blowing at more than 500mph.
The planet is unusual because it is tilted right over on its side. Astronomers believe this was caused when Uranus was given a mighty whack by another world in a cosmic collision.
More than 160 scientists are backing the Uranus Pathfinder project which is led by Dr Chris Arridge, of University College London’s Mullard Space Science Laboratory in Surrey.
He told Skymania in an exclusive interview: “We’ve only really scratched the surface of Uranus. It is very difficult to observe from Earth because any detail is smeared out. Since Voyager flew by we know the rings and atmosphere have changed. We need close-up measurements. Uranus is ripe for learning a lot from. It is so different among the planets.
One of the big mysteries about Uranus is that it doesn’t emit much heat at all. Its axis is also highly tilted to its orbit so essentially it rolls around the solar system.
Uranus takes 84 years to orbit the Sun which leads to extreme seasons. Dr Arridge said: “Because there is so little heat coming from inside Uranus, its atmosphere is completely driven by force of sunlight. And because it has got this large tilt in its axis one pole is continually in sunlight for 42 years while the other is in darkness and then the situation is reversed for 42 years.”
Uranus Pathfinder is being proposed as an M-class (medium-class) mission for ESA. But Dr Arridge said: “We see this as medium scale only in terms of price. For the amount of science you get back it is a large scale mission for quite low cost.”
